SAS front drive shaft???
7978 Views 9 Replies 9 Participants Last post by  Iverson
do i use a driveshaft from 84-85 to pull off a SAS swap? i tried a search but didnt get anything, i went mudding all last week and have it in my veins and think iam going to make my truck a ultimate off roader (for a student budget LOL)... thanks for all the feedback
Adam :welder:
1 - 10 of 10 Posts
I took off my IFS Dshaft, sent it to Jesse at High Angle Driveline at least a week before I had benup torch off my IFS...called Jesse when my swap was done and gave him the yoke to yoke measurements of my setup...and 2 days later my dshaft was at my door. I killed 2 birds with one stone, cause I added a crawler before the swap, otherwise I would have had to get driveshafts done again.
Some people make square driveshafts. They are strong and fairly cheap, but they don't balance.
I just went to the local drive line shop and they whipped one right out for it. Maybe $200 or so. No biggie, with the radius arms because a long slip is not needed since the driveline is more or less a constant length all the time.
thanks for the help guys... did some research through other forums, and found that all pro themselves sells a long slip shaft for 175.... thats not to bad...
thanks tho
Adam
really? didint know allpro made a shaft. Got a link? the adapter alone runs around $150. I would buy one right now if it was ready to go bolt in.
Not an entire shaft, just makes your current shaft into a long travel.
All Pro
AP doesn't make a shaft. They sell you the components to make it a long travel yourself or to have someone do it for you. I had Jesse at High Angle make me a long travel for 299. Love it. I'll break everything up front b4 I break that drive shaft.
Tim
thanks tho
Adam
So does marlincrawler.com: http://www.marlincrawler.com/htm/axles.htm
I did a SAS on a 1989 with a 1986 solid axle what do I need to do to my drive line to make it work?
1 - 10 of 10 Posts
