http://ezadventures.com/images/2004toyota009.jpg http://ezadventures.com/images/2004toyota012.jpg
2004 Tacoma Extra Cab 2.7 5spd in Atlanta GA
Doing SAS on Feb 27th Selling all removed parts
Will Knox 1 770-517-8407 [email protected]
SOLD TIRES 32-11.5/15 BFG MT's 4K miles with or without SOLD 15x10 Aluminum BAJA's - $760 with wheels $425 without.
SOLD COILS Front Coils
SOLD2 inch coil spacers with rear shocks- $50
SOLDCHAOS FAB diff drop kit - $25
SOLD CV's exelent shape $110 each or $190 both.
SOLD Front Diff with 4.30 gear $180
Toyota Aluminum Skid Plate $80
SOLD R&P Rear 4.30 gear
Rear Carier for 4.30 with Spider Gears - $80
SOLD Rear Lock Rite 4K miles (8.4'') $150
31-10.50 factory tires (26K) on steel wheels with never used spare $150
Disc Brake Assembly hardly used Calipers/Pads/Rotors/Hoses/Speed Sensors All in great shape ( 8mm of Friction Material ) $125
ABS Pump and Modual - Cost of Replumbing
A Arms and Spindles w/ball joints $100
Rack & Pinion Steering $ 225
Airbags with steering wheel $420
SOLD LC Engineering Muffler 2 1/4 inch outlet and inlet $30
SOLDSMITTY BUILT NERF BARS Black - $115
Rear Springs- $100
Sway Bar- $30
Factory Skid Plates already cut for Diff Drop- $70
Stock Shifter - $30
SOLDStock Header ( pre cat cut off ) - $35
Fan with clutch ( taken off at 8K ) - $35
90 Toyota Pitman Arm NEW Japan OEM Part - $60
SOLDOil Pan and Pickup - $30
SOLD Stock Shackles - $35
Steering Shaft Parts - $55
SOLDDana 44 Carrier, Ring and Pinion, Spiders - $50
Dana 44 Knuckles - $55
Rear Springs- $100
Sway Bar- $30
Stock Shifter - $30
