Well, things have changed, and I will no longer be doing a SAS on my truck, so I need to sell the parts I have collected. Everything is brand new in the box unless otherwise noted. All axle/gear/locker parts are for a Waggy Dana 44. If you're not sure about something, just ask. All prices are
OBO and
plus shipping from 98926. Here's what I have...
Click
here for pictures.
Yukon 4.88 Ring and Pinion Set..... $150
Yukon Master Instal Kit..... $110
Lockright Locker..... $250
Warn Hub Fuses (pair)..... $25
FROR Toyota to D44 25" Stainless Brake Lines (2)..... $70
Inner Axle Seal (2)..... $15
Spindle Bearing Kit (2)..... $30
Spring Perches (pair)..... $15
Raybestos Brake Pads P/N SSRD52 (set)..... $40
Steering Shaft from a 1992 Pickup (used)..... $35
Cardone Brake Calipers P/N 18-4208/9 (pair)..... $35
Oil Pan Swap Parts..... $150
FROR T-Case Crossmember..... $225
Wheel Bearings (all the bearings for both sides)..... $60
FROR 16" Shock Hoops..... $75
PORC Steering Stabilizer..... $40
U-Bolt Flip Kit (has the one bigger u-bolt for the D44)..... $60
Trail Gear Bumpstops (pair)..... $30
Dorman Wheel Studs P/N 6102641 (12)..... $20
