The coilovers are Saw combined with Fabtech spring and top plate. This setup rides so much nicer then the regular 2.0 saws. Included is the spanner wrench and the top bolts, and are already set at 2.5 inches of lift. These coilovers are in good shape except some cosmetic scrapes on the lower part and youll need to install new heim (12-14 bucks a piece from SAW) joints. Very easy to install just pull the o-ring and they pop right out. You might want to recharge with nitrogen. Asking 325.00 obo Email me @ [email protected]
The shackles are a custom built they will give you 2.5 inchs of lift and includes a brake valve lift bracket thats also set at 2.5 and has all the neccesary washers bolts and nuts. asking 55.00
This is what the truck looked like with the above lift on:
