1 - 2 of 2 Posts
im selling my seats and they guy that wants to buy them has a 4x2 reg cab.will they bolt in and if not whats needed
The 1995.5 - 2004 Tacomas used the same bolt pattern for all seats. However, the Regular Cab single bench seats didn't use all 8 bolt holes (that the buckets / 60/40's used). The unused (Reg Cab) bolt hole locations are either (a) pre-drilled and plugged or (b) pre-molded into the floor and need to be drilled out.
If your seats are 60/40's rather than buckets ... The driver's side '60' seat *may* use a different mounting hole (into the center hump) than a regular bucket. I've seen reports of 60's having a different bolt location on 1 hole, and I've never been clear which models / years this applies to ...
Hope this helps ...
1 - 2 of 2 Posts
