Installing my new optima and need to remove the fuse block from the casing, so I can legnthen the wire...
How the hell do it do it. Kep yakin but it aint budgin. Looked in the FSM, didn't find anything.
Thanks.
Thanks.
very carefully pry the tabs open, it will slide straight up out of the bottom box
Tabs?
Run out to the truck.. Hold on
Got it, one on each corner.
Thanks LAW
Discussion Starter · #7 ·
you know you can extend that wire without taking the whole box apart..
i forgot to mention that :p
Has a different approach.
Trimmed about 1/2" off the bottom so that the wire comes up. Then put the cable at a 45 degree angle instead of a 90.
Works great, but cables are tight. May eventually extend them.
