99 taco 4wd trd 3.4l, cornfed spacer w/diff drop
I fixed my passenger side wheel with a new lower ball joint. On the driver side, I have replaced lower ball joint, it has a 1yr old CV axle, I've replaced a busted outer tie rod, and my upper ball joint appears to be good. But that left tire is still wobbling with the slightest bumps in the road. I may just be weak but I could not get it to shake on a jack. It also makes a soft knocking noise that I can only hear and feel under my feet at low rpm's.
I know my sway bar bushings are shot, I'm picking up new bushings today but I am definitely not betting on that being the fix... Any ideas?
Thanks for your help,
mark
Have you checked out the wheel bearings?
check out the inner tie rods also
It's a bushing around the steering knuckle. Excuse my ignorance but I think that's what it's called. I know there's a write-up in the tech faq so thankfully I can take care of it. Thanks!
