I took my shell off yesterday to put my over-the-rail bedliner back in, because i didn't want to scratch the bed up too bad. Today it is pouring outside, and the shell is leaking at the seal to the bedliner. Is there anything I can do to stop it from leaking other than cutting the rails of the bedliner off?
For starters, take the bedliner back out. It will do more damage than not having one at all. After 3 months in my '03, the paint was abraded down to bare metal on all the high spots of the bed. I use a rubber mat, much better. If you're still determined to use a bedliner, get an under the rail liner. I'll bet there are a bunch here who would offer one up for free.
Like bb609 said, the liner will damage the paint, mostly on the tops of the rails where the shell sits.
If your determined to use the liner put foam sealer between the liner and the shell rails (1-2" wide stickey on one side) , it'll help seal any openings. Replace the foam everytime you remove and replace the shell or about once a year. I did this on my 94 Toyota for 5 years and never had a leak.
Tim
Tim
My truck originally came with an over the rail liner. I ordered a cap through the dealer so they swapped the liner out for an under rail type. Just from sitting on the lot, I have nice pin stripes down each side of the bed rails where the old liner abraded it. I complained to the stealer and they gave me a bottle of touch up paint. Fawkers! I have plenty more to match them now anyways! lol!
Thanks for the info guys. I've had the liner in for almost 4 years now, so it has already worn away the paint on the bed rails and in the bed. I wanted to keep it over-the-rail to cover up the scratched rails that are exposed when the cap is on. I'll try the foam sealer that was mentioned. Ideally, I would like to get a spray-in over-the-rail bedliner, but that isn't going to happen anytime soon.
That was going to be my best answer for ya...
always a Toyota lover at heart
throw away the plastic bed liner and get a Spray in bed liner, over the rail FOR GODS SAKE !!!!!! LOL
You will be very happy with it and it it permanent to the bed rail
