1 - 3 of 3 Posts
I have my OME rear springs installed along with OME shocks and when use my highlift to lift the rear, off my sliders, the shocks bottom out way before the springs. I was wondering what shocks to run in the stock location, or should I shell out the $ and setup the rear like this /\. I would like to put some 5100's in since they are back in stock, along with not having to go crazy with the setup.
· Administrator
The reason the shocks limit your flex is due to shock length. You can't run longer shocks without bottoming out during compression. Changing to a / \ set-up allows for longer shocks, but you lose some shock efficiency when you go to that configuration. Cutting into the bed with shock towers is another way to run longer shocks. :welder:
Why did I know you would say that. Looks like I'll go with the bracket from ORS to make them /\. Now I just need the welder :welder: Anybody Else?
1 - 3 of 3 Posts
