Isnt it always great when people give you threads instead of answering your question. Personally, IMO I dont think that you have enough bed room to worry about losing space anyways. And you can always make it so that it is removable like mine.ah64id said:I read thru all those before asking.. saw a lot of good info.. but figured I'd ask the more specific ?....
same here, mine is mounted with one "J" bolt on each side hooked into the bed rail system. so it can easily be removed if i need to.tbst said:Isnt it always great when people give you threads instead of answering your question. Personally, IMO I dont think that you have enough bed room to worry about losing space anyways. And you can always make it so that it is removable like mine.
Im sure he thought they'd be helpful atleast. Its better than flat out telling someone to search.tbst said:Isnt it always great when people give you threads instead of answering your question.
boydestruction said:Also, a note about the OEM box to the previous poster: In theory you could slide it along the rail system (though you would have to loosen the bolts and re-tighten them after you move it), but it has three attaching points - two on each side and one that attaches to the rail below the windows in the front of the bed. So, if you were to slide it along the rails you would be without the third attaching point.
I like the OEM box, I've had mine awhile and it attaches easily and holds all my tools, compressor, recovery junk, and more keeping it all secure. The box allows me to keep it all with me all the time so I never forget stuffocdropzone said:hey Rotorhead: I thought I posted some good info...![]()
Check out this pic's towards the bottom of this thread, http://ttora.com/forum/showthread.php?p=649988#post649988
It has got some great angle shots showing the factory toyota box mounted in a short bed DC.
IMO Deflecta shield box offers a good compromise since it gives you lockable storage but doesn't take up a third of the bed...
