1 - 9 of 9 Posts
Anyone know if an 05 side step bar will fit an 06?
Factory side steps? It should as long as it has the same cab configuration. EX. A double cab short bed might not line up the way a single cab long bed would.
No, it's not factory. It's the 3" tube side step. For some reason the bracket fit on the rocker panel but when i put the step on, it seems off about 4 inches. Is the body lenght the same for 05 and 06 model?
it shouldnt be unless they are different cabs or beds
unless you got a long bed vs short bed im pretty sure holes line up.. try switchin sides wit sliders...:2cents:
I try both. the first two brack will line up but the rear brack is off about 4 inches. I'll try again tonite after work. Will let you guys know how it goes.
Discussion Starter · #9 ·
problem resolved.
1 - 9 of 9 Posts
