I've wanted twin sticks for quite some time now since I mob around in low range unlocked it seemed like what I wanted. There is no kit for the w series forward shift since it uses the trans base for shifting.
What you need for this is one shift rail and collar from a top shift case and a topshift shifter.
Pop the rear output flange off. Pull the two rear most covers off the case.
Drive the roll pins out and remove rail from front of case.
Pull forward case from truck and repeat same steps. I had to cut off a portion of the collar as it hit the gear but its easy to do.
You also need to weld a little material to the forks so the shifter stays on the rail.
Reassemble with one forward and one topshift rail and enjoy your twin sticks.
