1 - 9 of 9 Posts
I tried to order a pitman arm insert from Sky Manufacturing, and they said that they wouldn't be back until the 28th. I really need this adapter, does anyone know of another place that sells them? Thanks.
I have a stock pitman arm off a 4-runner that has the insert in it. It has a little bit less drop than a regular arm. I milled the insert at school, tapered it for chevy TRE's, and had the insert TIG welded in by the welding teacher.
$40 shipped, I can get you a pic if needed, just PM me.
Thanks! BTW, I think FROR sells just the inserts?
· Premium Member
Call Brian Ellinger, he can send you one.
Later,
....Mike
took a piece of 1 1/4 bar stock, drilled out the hole in the pitman arm to 1 1/4, chucked the bar stock in the lathe and drilled out the center, then left it in the lathe and ran the tapered reamer up in it. Since it was not a press fit into the pitman arm I had a teacher TIG weld it in. Did all that work and then I wasn't even able to use it because it had too much drop and was slightly too long. If you have your stock pitman arm, I will do $30 shipped if you send me that arm, as a friend was going to buy this one, but I can make him another if you send me your arm.
Thanks!
Here is a pic of the arm, it is 6 1/4 from center to center of each hole. 3 1/4 from top to bottom of the arm. Is this less drop than a regular truck arm? Come to think of it, I don't know what it came off of, I got my steering box off a 4-runner, but I traded some guy some u-bolts or something for this pitman arm. It does fit a toyota steering box though, as I had it on mine at one time.
· Premium Member
Brenton, I seem to remember telling you that I had an extra pitman that came off a pre taco. if you want to get together sometime to see if it will work for you, let me know. I have lost your phone number otherwise I would call.
D'oh just realized that the number is in your sig. Listen for your phone to ring!
Hey Michael. Thanks for the offer! I can machine a press insert, but I would rather spend $20.00 than jack with that. It shouldn't be a big deal though. When I asked you how you milled it, I thought you meant that you used the mill to machine the entire piece, that you never used a lathe, so i was a bit confused. I guess you could use a mill, you'd just have to get the radius of the insert perfectly round, which would be pretty damn hard without CNC. Anyway, I'll probably just machine one tonight. Thanks for the help.
Food for thought. Parts Mike sells a modified landcruiser arm that fits the Toy IFS steering box and is milled for the GM tie rod end. I know a lot of people use the insert without problem but I still prefer the one piece arm. I believe I bought mine for around $120.
1 - 9 of 9 Posts
