Hi,
Someone have this problem with the fabtech 6" lift kit on his tacoma? When I put the front crossmember lift kit, this one doesn't fit because the oil pan has been change (I think by the last owner) and the oil pan block the crossmember. I decided to modify the Fabtech Crossmember. I cut a little bit and weld a metal plate (I will put a picture tomorrow).
So, someone have this problem?
David
haha, i would rather replace an oil pan than cut and weld a lift component
yeah i would have changed the pan before fucking around with a lift componet. I do want to see pics though and see what you did. Also your post is hard to read. You might want to read your future postings out loud before you post them.
So what do you have a V6 or a 4 banger? you should have asked around on the board before you modified anything.
For the quick fix it would have been easier to get a new oil pan. If you have a v6 and want to replace the oil pan let me know. I have one off my 97 that I removed when I did my SAC.
I'll let you have it at a good price if you want it.
