1 - 13 of 13 Posts
Ban Count: 12
If I let off the gas while driving, I get a squeaking, squealing, ringing... whatever you wanna describe it as. Push in the clutch pedal, it goes away. Give it more gas, it goes away. Put it in neutral, it goes away. Your thoughts?
yep.sounds like the TOB. i ordered the whole clutch kit from jaque and im installing it next weekend.
the squeaking and squealing got worse and finally started clunking.
Sounds like a throwout bearing to me
Eats Own Boogers
The TO bearing should only spin (and potentially make noise) when your foot is pressing the clutch (changing gears).
so i just did my 01 v6 4wd drive, w/ a factory clutch and i hear this light humming/buzzing when i apply the gas peddal, it stops when i let of the gas? any thoughts?:confused:
Eats Own Boogers
I just did mine over the Christmas Break. It seemed that I was noticing trans bearing noise, but I know that it was just because I was listening "too much". I'm not sure what else to tell you though....
Probably harmonic resonance in something. Remember that there's a few thousand little thing on the truck that can buzz. Have you tried to track down the buzzing at all?
:doh: May sound stupid but I've had a loose nut on the intake stuff near the head/block make a sound just like a throwout bearing.............get someone to help you and feel the suspected areas until you pinpoint the rattle...........
Wait a minute who the hell am I telling this too...........:doh:
1 - 13 of 13 Posts
