anyone had an issue with the small spacers you can slide over your studs? Seems i put a set on and my brakes now have an awful issue like they are warped.
First thought is that you put lug centric spacers on a hub centric wheel. Second thought is that it's just timing. Did you take them off and see if it made a difference?
taking them off today, totally failed once again w/ this piece. Killed another wheel stud and I have a lug nut on the back that just spins so i can't get it off at all, tried impact and pullin on the tire. epic fail i'm about to :flamethro
just drove it w/ the one spacer still on there. brakes were back to normal i hope, i braked from 55 and it was smooth, hope its not a heat thing. tracked fine w/ just one spacer, going to try again tomorrow
