Cool just wanted to make sure since its a smaller rim that it will attach correctly to the spare tire mount.turbo4door said:Ive seen 33x1250s in the spare tire location, tight fit!
cloomis3 said:What exactly is bad about using a smaller spare? What will it mess up? Also, has anyone with larger tires ever kept the spare partially deflated and just used a compressor to fill it when the time came?
Your differential will hate you. If you were to travel a several hundred miles on the freeway with different sized tires the temp in the diff will be hot enough to start breaking down the oil and possibly do some damage to the bearings(diff friction=heat). There was some problems a few years ago with the new F150 spares being undersized. Needless to say Ford had to replace some rear axles and quite a few spares to the correct size. As for how many miles and at what speed I don't want to find out but I don't think a trip to the nearest station will harm it. On most cars that have the baby donut spares they even say to keep the speeds low and for very short use.cloomis3 said:What exactly is bad about using a smaller spare? What will it mess up? Also, has anyone with larger tires ever kept the spare partially deflated and just used a compressor to fill it when the time came?
Did you have the hidden-type factory tow hitch?generalee7 said:I fit a 35x12.5R15 under my bed in the stock location. It kinda rubs the shackles but it fits.
***********Off Topic**************generalee7 said:I fit a 35x12.5R15 under my bed in the stock location. It kinda rubs the shackles but it fits.
No sir. Took that shit off a long time agoDCabTaco said:Did you have the hidden-type factory tow hitch?
Hey, no I never finished the top. I started sewing the canvas and realized it was a bit harder than I had planned. I still have all the canvas and the frame sitting in my backyard, if only sewing was as easy as welding! :welder:wisctaco04 said:***********Off Topic**************
Generalee7-did you ever finish your soft top shell? It was you a year or so ago working on it right?
id just take one from a pick n' pull yardMy spare tire carrier part that looks like a u rusted and lost my spare. Does anyone know how to repair this bottom part to hold a spare again?
there should be an extra one in your jack tool pouch.My spare tire carrier part that looks like a u rusted and lost my spare. Does anyone know how to repair this bottom part to hold a spare again?
