1 - 10 of 10 Posts
Hi I have read a few posts on this. I am installing a navi system by Eclipse and I was wondering if anyone knew where to locate the speed pulse wire/senser. the other threads did not give any useful information so I thought I would get your attention again... Thank you for your responds, oh and I have used the "search" option... this is going in a 06 tacoma 4dr pre-runna
how do I find these wires, where are they located?
3 wires on the tcase.1=power, 1=grnd, 1=signal.
does that answer your ????
BTW, when I wire up the dakota digital devies I use those 3 wires and run up to box location.
tcase?
Discussion Starter · #7 · (Edited)
yeah prerunner here and using the context clues tcase= transfer case....thanks for your help though.. I did take a look under my truck at the transmission and about half way back on the driver side I saw a plug/connector near the top side of the tranny, would this be it? and what wires do I tap into?
that might be it. if you had the same tranmission as the 02's I could look it up in the manuals tonight for ya. not sure if same or not.
if the speed sensor is seperate from other conn. on trans, would have 3 wires, power grd and signal. use a meter or test light to find power. on mine, if I remember right, signal wire had color stripe on it and power and grd were solid color.
I need to bring this thread back. I'm installing an eclipse screen with navigation. I need to find the speed sensor wire, and reverse light wire. can someone give me a link to a wiring diagram. I have no idea if the wires on an 05 tacoma are the same or an 01 tacoma 4x4. Any and all help is greatly appreciated. thanks guys.
Does anyone happen to know where these wires are. I've heard, Tcase and Trans. Which one? and What color are they. Remember, its an 01 Tacoma 4x4.
1 - 10 of 10 Posts
