Is a regular pickup wired for an sr5 gauge cluster? If so shouldn't I be able to wire an aftermarket tach into the plug to get power?
OnlyHereForTheTires
if you only have a 'dummy sensor' for your oil pressure you'll need to swap that out on the engine for it to read correctly on the new gauges. theres a really good thread about this on yotatech. i'll see if i can find it.
also, the rmps might not ready correctly if you don't use the right 'version' of gauges, 6 cyl vs 4 cyl / auto or manual.
I have aftermarket gauges im putting in. I was just wondering if instead of having to run wires to the engine compartment if I could just keep them under the dash
I doubt it. Im sure the factory tach will run off the computer. Run the wires boy.
