Sick of having to push the clutch in every time you start your rig?
-Look toward the floor under the clutch pedal, See a switch? [one that your clutch pedal pushes down when its pushed all the way in]
-Note the color markings of the two wires on this switch
-Pull the 'Start Clutch Cancel' switch out of your dash--- A really small flat head screw driver works well to get it popped out
-Unplug the switch
-find the two wire colors that are also on the switch by the clutch pedal and jump them together
Now you wont have to push that stupid switch to start your rig with the clutch out! And, can make better use of the new hole in your dash for another switch.
Great for: Those early mornings when you head out to warm up the truck [dont have to sit in that cold seat to start her up]... Those tight spots wheelin when you need to use the starter to slowly get you out of something [
To all of you Crawler guys]... Just feelin' lazy!?!
Dont run over any old ladies in the parking lot because you forgot it was still in gear though!!
-Unplug the switch
