Anyone ever bought a bad filter? Changed the oil a couple of weeks ago. The past 3 days noticed sounds like no oil pressure at start up (the same sound you get after changing oil and filter). Thought maybe the anti-drain valve on the filter was bad? Going to put on new filter tomorrow.
2001 Dbl cab--stock
what brand of filter? i know some people have gripes with frams, but i have yet to see any ill effects from it.
Is this on a cold start? goes away pretty quick then Check your fuel injectors, they or the fuel system may need to be cleaned. Thet leak down when left overnight in cold temps... loading up the cylinders with fuel causing the rap. Well I just fixed Two differnt Toyotas with this problem.
Ok, it was late....only filter they had at Wally World was Supertech--the store brand. Yes, cold engine but the temps here in Virginia have been pretty mild the past couple of weeks. I'll throw some injector cleaner in just incase.
