those of you running steel wheels, are you getting any vibration? i noticed that the steel wheels are not hub centric. i use to have 18" wheels that needed hub rings to get rid of the vibration.
Stock Toyota wheels are hubcentric...KStacoma said:The steel wheels i have are lug centric, same as stock.
i'm gonna get the steel wheels from wheelersoffroad.com...15x8 i believe the 3.75 BS (Type B)TacoCrazy said:Lug-centric is correct..No probs with mine,,I run 33x10.5 BFG M/T's, smooth as glass..
i have that exact set up...no problems whatsoever.04RedLobster said:i'm gonna get the steel wheels from wheelersoffroad.com...15x8 i believe the 3.75 BS (Type B)
would i be able to put in like 32" tires with those wheels with no prob?
