I noticed that some of you are running your steering box with it tilted forward rather than being level to the frame. What are the advantages and disadvantages to bolting it on at an angle?
You want to get the pitman arm as close to the frame as possible so it doesn't limit compression on the driver's side. If necessary, there are flatter pitman arms out there than the stock Toy stuff.supahonkey said:I noticed that some of you are running your steering box with it tilted forward rather than being level to the frame. What are the advantages and disadvantages to bolting it on at an angle?
like mike said you can run a flat pitman arm. here is a pic of mine, when i first sleaved the frame for the DOM inserts i didnt allow for enough room for the flat pitman since the box i had had the drop on it and i didnt have the flat one yet. so i had to patch up the frame, redrill and plate the frame again, during the process i ran out of wire so i just used a stick welder. it has since been redone from this pic with 3/8" plate on all 4 sides of the frame and come back about 14". and yes with the box straight up your steering shaft angle wont be the best but mine does not bind and works for me. i used the sky manufaturing flat pitman arm and drilled it out for 3/4" bolts to use with hiems.Hunt4Steve said:You guys have any pictures on these. I'm planning on using 12" coil-overs, could I then tilt my steering box slightly?
I was also under the impression that if you tilt your box slightly, you decrease the angle of the U-joint for the steering shaft.....This is a good thing, correct?
The clearance issues are with drag link end hitting the leaf springs when compressing the drivers side. With coil-overs I can't think of any related clearance issues - so I would think you can mount your box however you feel likeHunt4Steve said:I'm planning on using 12" coil-overs, could I then tilt my steering box slightly?
