1 - 9 of 9 Posts
I just bought an 04 Tacoma 4x4, and the steering wheel must be turned slightly (25 degrees) to the left when the truck is going straight. It is just enough to drive me crazy. Has anyone else had this problem? Is it common in Tacomas? The truck does not pull to one side or the other so I dont think it needs alightment done. Is there a fix or something I will have to learn to live with? Thanks for any info.
get an alignment
yup, steering wheel alignment.
X3, mine was like that after I cranked down the CO's. I believe its the toe of the tire that causes that......is your truck lifted?
get a front end alignment done but also have the shop run the rear out or do a thrust angle alignment both are the same just different terms (they'll know what i mean) to makesure the steering wheel comes out streight and if it's not take it back and have them align it again untill it's right.:)
Yep, aligning the steering wheel is part of a correct and complete alignment job. Any shop that says "as long as the vehicle drives straight..." is full of shit.
Actually, what I'm inclined to think is someone has been working on the steering, or maybe lifting the body, and has reassembled the rag-joint slip collar one tooth off. Having an alignment monkey try to compensate by adjusting the tie-rods to be unequal may not be the best thing if that's it.
Discussion Starter · #9 ·
Thanks guys.
Seems simple enough. My truck is stock (for now anyway). I am taking it in next week. I appreicate the info... This is a great forum.
1 - 9 of 9 Posts
