1 - 8 of 8 Posts
so im starting the leaf pack rebuild and im upping it to some poly bushings... but i cant get the old front bushings out of the leaves. i tried burning them out ( thats how the rears came out.) but i cant get the fronts out to save my life. am i just not burning them enough or is there something else.... after about an hour of fawking with it i got pissed off and went inside.... but it has to get done eventually
Big tars, little bed.
Torch. More torch. More torch. Lots of torch. Then use some backyard method to cut out the metal sleeves. I used a sawzall. Careful not to cut the spring though.
dont they make some miracle grease??? lol
Not sure bout miracle grease :D but trust me those sleeves dont wanna come out and their isnt much room to get grease in there.
Installing brand new factory bushings after I got the old ones out was cake. Just a few whacks with the BFH and they slid in.
But back to getting the originals out, its insane. I burned mine until the rubber was bright orange then I just let them cook. Retorch as needed. The rubber expanding pushed out the bolt sleeve, then once burned completely and cooled I scraped the rubber out, then sawzall'd the outer sleeve. Miracle grease. No way. I dont see any other way to do it unless you have a 10 bajillaton press. Trust me I tried many methods but the one that worked was burning them out.
yeah the backs came out cake..... but the fronts i even tried to jack the spring up against the bottom of the camaro.... picked up the whole front end and it didn't even budge....
When ordering my OEM replacement bushings I noticed some trucks had different bushings front to back of the spring. Mine however were identical. I dont know exactly why but mine were both 1 piece yet some Tacos got 2 piece bushings in the rear and I recall thinkin those would be hell to remove. Actually the 2 piece came up on the catalog as the correct replacement for my 00 taco, yet I told the parts guy mine came with one piece and thats what I wanted even though the system showed the 2 piece as the correct part.
1 - 8 of 8 Posts
