While I was under my truck last weekend replacing my outer tie rod and boot I noticed my sway bar stock 'end' bushings severely mushed and cracking badly - I'm sure they're stock.
The only ones I can find are from Energy Suspension. They listed 2 options for the bushings - a 26mm and a 27mm. Not even sure what's measured, so I have no idea which of those I have.
I have a set up steering rack bushings from energy I installed about 5 years ago and they're holding up really well.
Anyone ever run into this and know what this measurement is ? Does 1 mm really matter ? Perhaps it's the diameter of the hole of the end eyelit hole of the sway bar?
TIA
Discussion Starter #2
After some more searching, I found out that the measurement is the outer diameter of the sway bar near the center bushings - all I have to do is break out my digital calipers and measure.
Easy fix...take sway bar off...throw away. :) It gives a feeling of freedom as you swerve down the highway.
