I know i asked this question in the old forum but the pros and cons of synthetic vs. wire wire is more durable right ? and 1/3 the cost? 3 times the weight. but really what do I need ?
If price is a factor someone gave me this link earlier in the week. They have synthetic line for pretty cheap. http://www.okoffroad.com/xcmountain80 said:I know i asked this question in the old forum but the pros and cons of synthetic vs. wire wire is more durable right ? and 1/3 the cost? 3 times the weight. but really what do I need ?
I love the synthetic, no more rope slivers or cuts, it's basically weightless to carry or throw up a hill and the safety factor is huge. It's also stronger than wire rope inch for inch. The drawbacks are succeptibility to abrasion damage and heat but if you're careful you can usually avoid rubbing it on stuff or use a chaff guard. Heat really isn't an issue unless you power out a lot of line on your winch. If I ever wear out the rope I have I'll order it again, it's awesome.xcmountain80 said:I know i asked this question in the old forum but the pros and cons of synthetic vs. wire wire is more durable right ? and 1/3 the cost? 3 times the weight. but really what do I need ?
I worked on a prarsail boat for two years and the line we used was made of a stuff called spectra. We had 1000ft of 5/16 line on the spool, I THINK it's max load rating was like 24,000 pounds but working load was like 14,000 pounds.Uneasy Rider said:Is that synthetic line some kind of Kevlar (armid fiber) or is it just a strong type of nylon? thanks just curious here.
I've been using synth for awile now, and I'll never go back to steel. It's just way way easier to work with, and much much lighter.. and size for size, stronger. It's so nice just being able to toss somebody the line, and to be able to pick up the entire length in one hand, and not worry about sticking yourself with barbs or the line whiplashing around when winching. It's also much easier to spool.xcmountain80 said:I know i asked this question in the old forum but the pros and cons of synthetic vs. wire wire is more durable right ? and 1/3 the cost? 3 times the weight. but really what do I need ?
The primary reason you should use it. Well worth the $$Front Range said:Synthetic. I dont want to be resposible for someone death/injury, including my own.
Thank you! I hate playing medic on the trails. Ive put enough people back together not hit with winch lines, Id rather not add that to the list.xcmountain80 said:Ok I went and bought one !!!!!!!!!!!!!!
Aaron
Depends who's it is. Amsteel Blue (what I run) is UHMW. Ultra High Molecular Weight. Suffice to say, really cool plastic. 5/16 cable BREAKS at 9800 lbs. 5/16 uhmw is around 13500.Uneasy Rider said:Is that synthetic line some kind of Kevlar (armid fiber) or is it just a strong type of nylon? thanks just curious here.
Front Range said:Thank you! I hate playing medic on the trails. Ive put enough people back together not hit with winch lines, Id rather not add that to the list.
