ok guys so every once in a while i notice my tachometer needle stays at zero on idle, as soon as i give it gas it works but when its idling it will drop at zero but the engine has no change just the needle. could this be a ground issue or what else should i look into
Pull the whole dash appart and check the wire connections on the back on the pod.
sometimes there is a static buildup on the pin that the the needle rests on.
open the guage cluster and wipe the needle with a q=tip and alcohol
ok guys thansk ill get to takign it apart tonight
