1 - 13 of 13 Posts
Found these in my Cabelas catalog today after a friend of mine installed them on his truck. They are great! My wife is heading to Florida for about 10 days the first of the month so it will be a good time for me to pull out hte credit card :D Mike PS Check these out, click on the small pic and you will get a big picture. Cheap too! $29.99 including brackets and wireing. Can be wired to work with your reverse or to a seperate switch.
http://www.cabelas.com/cabelas/en/templates/purchase/products-found.jhtml?_requestid=35478
Discussion Starter · #7 ·
Chadman said:
My bad, I didn't know there where some available for the 01' up tacos. Where doyou get them? :confused:
Go to the Cabelas web site and then to automotive and you will find them. They fit on any trailer hitch and can be wired for the reverse on your truck or they can be wired with a switch. Mike
Discussion Starter · #10 ·
Don't know if they are water proof or not and that's a good question. It's hard to believe that they would sell lights to be mounted under the truck on a hitch unless they were water proof. On second thought you never know today :( . Cabelas are really great about backing there products or returning your money. Been dealing with them for many years and never had a problem. Mike
Just get a Hella worklamp, it's only $13. It's water resistant and they are 55 watts, they light up a lot behind you. You can get some stainless steel hoseclamps and mount it to your trailer hitch underneath. I left mine a little loose, so if it gets hit by something it will move.
Go to http://www.rallylights.com/hella/rubber_worklamps.asp They have awesome deals and the owner is great to deal with. You can also learn to hook them up there.
I wired a relay into my back-up light switch on the tranny, so mine come on w/ the back-up lights. Also I have a switch where I can put them on from the cab for setting up camp or letting someone driving behind you to turn off their high beams :D ...
· Premium Member
Oh I now have some additional lamps mounted inside my rear bumper for back-up use. However, I do have four of the Hella utility lamps you mentioned as part of my rock light setup.
1 - 13 of 13 Posts
