1 - 20 of 22 Posts
4x Innovations has created the first true super duty transfer case/transmission mount for Toyota Tacomas! In this new mount the soft, weak, stock rubber portion of the stock mount is replaced with quality Energy Suspension poly round bushings. These bushings will not split and fail on you, relieving you of such worries associated with stock mounts. They are also strong enough to handle the worst conditions while eliminating your transmission and transfer case shifter slap. Your new mount comes with thicker steel plates that are laser cut and CNC formed for the best fit possible. This mount is a direct replacement. You can even run this mount with after market cross members that reuse the Toyota rubber mount.
As if all that wasn’t enough, there’s another trick feature to this mount. If you need remove your transfer case or transmission you now only need to remove two bolts from the bushings to pull the cross member down, not the 4, hard to get to, bolts that engage in the cross member.
Tacoma transmission and transfer case mounts fit 4WD Manual Transmission found in 95-04 Tacoma with a 5VZ-FE (6 Cylinder) Engine and come assembled ready to bolt on with a clean black zinc plate on the outside. They are $99 plus shipping.
To order please either call us or click over to 4xInnovations.com and use the online shopping options.
These are in stock and ready to ship, order yours today!
So, by your description they do not fit 2001 Tacoma 4 cylinders with automatic transmissions?
How are the vibrations? I have read here that if you switch the mounts to poly they all have to be switched(motor mounts etc.)
Discussion Starter #9
We have many people running just the t-case/trans mounts and they LOVE them. Talk with SarSquid for one, plus litterally hundreds of others.
1 - 20 of 22 Posts
