I own a ' 96 Tacoma 4x4 with the 2.7 engine. Today I installed a Hoppy trailer wiring kit and now I have a problem. All the tail lights worked before I installed the wiring kit. Now after the installation, the drivers side rear turn signal is not as bright as the passenger side.Also, when I step on the brake pedal with the directionals on, the directionals quit working. As soon as I let my foot of the brake pedal, the directionals will start working again.I did noticed some slight corrosion on the blades inside the factory connectors so I put some protective grease on the blades before I put everything back together. Any ideas?
