Ok, so I need to chose between a Lincoln SP 175T and a SP 175 Plus the only diff is: Output range 30 -175 vs 25-175 & the control (tap vs continuous). What is the diff? is it worth it?
Tap voltage control gives you like 8 different preset voltage settings. The continuous control is variable across the whole range. Having the variable control allows for more precise adjustment of your voltage to fine tune your welding.DirtWorshiper said:Output range 30 -175 vs 25-175 & the control (tap vs continuous). What is the diff? is it worth it?
