1 - 14 of 14 Posts
ok i have been search some and couldn't find the answer maybe i am using the wrong key words but here is my question..........
what is the teeth count on a 4.10 ring gear and what is the teeth count on a 4.88 ring gear. booth are for a front diff front also if that makes any diffrence.
thanks jesse
Big tars, little bed.
thanks jesse
41 on the ring of a 4.10:1 10 on the pinion
thanks jesse
the ratio should be stamped on the side of the ring gear
yeah i was mainly wanting to know on the 4.88's, so it should be stamped on the ring i will check that.
the ratio wasn't stamped on the side of the "4.88" ring i searched for a while didn't even try to find it on the other one it is a 4.10 gear counted the teeth easy enough. i am about 99% postive the one is a 4.88. it has 39 teeth gear so if i divide that by 8 i get 4.88 or it would be a 3.9 with 10 tooth or a 4.33 with 9 tooth....... and so on
then it must be some off-brand of gear. OE, PG, Yukon, etc all have the ratios stamped on the ring.
gixxerjesse said:
as far as i know it is the stock toyota gears, out of a 95 4runner
and nothing at all is stamped on the ring...interesting. All the OE Taco rings have the ratio on them like 3.5, 3.9, 4.1, etc. they leaf the 3rd digit off.
Discussion Starter #10
as far as i know its not stamped the dif is still together so it may be stamped underneath the bolts that hold it onto the carrier. i had checked for about 10 minutes or so because i have been told what you say is the word of yota but still no find.
only if Yota is a better BSer than I :p
Discussion Starter #12
it was brian33sc that told me that so i will let you make your own judgement
that explains a lot :rofl:
how drunk was he at the time? :p
1 - 14 of 14 Posts
