they don't make them for Tacos or didn't the last time I emailed them. the trick is to come up with some sort of quick disco for street/trail use. some fab shop in Tx was supposed to be working on like them for our truck.synovus said:Anybody have any experience with Teraflex's Revolver shackles? Pro's/Con's?
I think I remember that now. I remembered a thread, but wasn't having any luck finding it.KStacoma said:I asked a while ago about revolvers and people sorta flamed me by saying that i'm crazy
I knew I was forgetting a question (whether they have 'em for Tacos).hytenor said:they don't make them for Tacos or didn't the last time I emailed them. the trick is to come up with some sort of quick disco for street/trail use. some fab shop in Tx was supposed to be working on like them for our truck.
good question. I would think not since the problem is overflexing on emergency maneuvers or taking turns too fast. I don't think a sway bar would really prevent that but I'm just guessing. As suggested, some sort of pin type disco should work. Fab some up and let us knowsynovus said:I knew I was forgetting a question (whether they have 'em for Tacos).Would using a rear stabilizer with quick-discos work in lieu of quick-discos for the Revolvers?
Yeah, after posting I realized a sway-bar probably wouldn't handle the loads, just help a little. I'll be sure to let you know if I come up with a quick-disco solution for the revolvers!hytenor said:good question. I would think not since the problem is overflexing on emergency maneuvers or taking turns too fast. I don't think a sway bar would really prevent that but I'm just guessing. As suggested, some sort of pin type disco should work. Fab some up and let us know![]()
Could that be avoided by relocating the rear shackle/hanger?TMS2U said:Another thing about them is that essentially they are only designed to work when the resting shackle angle is close to zero (aka jeep!). I was looking into a set for my rear leafs, but my RSA is close to 45o and that would have resulted in the inside joint of the revolvers hitting the leaf on full compression. Thats a bad thing.
