1 - 20 of 40 Posts
The 4x4 conversion Guide (LOTS!! OF PICS!!)
The 4x4 Conversion
First off I would like to thank every ttora member that has helped me with questions and also finding parts. Thank You!
Now onto the conversion. First off you need to know that this is NOT EASY! It will take a few days. I made this post so other people thinking about doing it will see what is involved. I did this swap on a 99 V6 extended cab Tacoma. Below I have a parts list make sure you have everything up front.
Parts:
A340F Transmission
Front Diff (make sure it is the same ratio as your rear) (with the mounts)
Front drive shaft
Rear Drive Shaft
Left and right CV’s with end bolts
Front spindles/Hubs
4x4 shifter boot
A340F transmission mount (prerunner one wont work)
11qt ATF
Vacuum tank
Vacuum Tubing and 4x4 solinoids
Tools:
2 18” ratchet extentions
A 3/8 knuckle
Various extentions
Impact gun (if you don’t have one, harbor and freight sells a 18v cordless for $49. You will be happy you have it)
10mm-19mm shokets
Prybars
Jack (2 will make life a lot easier)
And other basic tools
Part One: Transmission swap
Disconnect your battery
Remove the console
Undo the bolts holding the shifter assembly down, and disconnect the electrical connection
Once you have the shifter out undo the rubber. Notice the oval, trim that out.
Once the oval is trimmed out it should look like this
Now place your rubber 4x4 boot/seal in. That’s it for the shifter.
Now remove the Drive shaft
Now remove the front skid plate
Remove the Flywheel inspection plate
Remove the six bolts on the flywheel, You will need a wrench on the crank pully to rotate the motor to gain access to all six bolts.
Undo the crossmember bolts, make sure you disconnected the 02 sensor conection. (make sure you have a jack under the transmission!)
Undo all electrical connections
Disconnect the started wires, and remove the starter
Disconnect the ATF lines
Now you are going to have to remove the bell housing bolts, this is where all the extentions come into play, there is also on bolt that is bolted to the bottom of the header… mine broke when I was taking it of… oops
Here is the layout of the bolts, so you know what your looking for. Make sure you have another jack under the bell housing. If you only have one jack, place a flat piece of wood under the transmission pan and place the jack under there.
NO picture for this step but you need to carefully remove the 2WD tranny. Then get the A340F tranny and slide it under the truck. Carefully lift it onto the two jacks.
I used a cherry picker the hold the rear of the A340F up
Now its time to jack up the new A340F transmission. Make sure you unbolt and remove the shifter so it isn’t in the way. Make sure the Dip stick tube clears the exhaust
When sliding the new transmission in take your time… this was the longest part… also try to make sure that the holes in the flywheel line up with those on the torque-o-verter.
Once you get the transmission mated up against the engine put the flywheel bolts back in. This will keep the flywheel and torque-o-veter aligned .
Then bolt the bell housing in. No pic, see removal. After that reconnect all electrical connections. Lower the transfer case end of the transmission this makes it a lot easier
Now bolt the crossmember in, and bolt down the mount.
Reconnect the ATF lines
Bolt in the starter
Make sure the top portion of the dipstick tube is connected, check the level.
Reconnect your 4x4 drive shaft
Place your modified shifter assembly back in
Hook up the shifter lever under the truck
That is Part one of the 4x4 conversion, sorry for the lack of pictures at the end. if you have any questions feel fre to ask
Part Two: Front Diff. and adding 4x4 spindles (coming soon)
nope im using vacume styalle ADD. i grabbed the wrong drive shaft from the junk yard so i am going to go back tomorrow and get the right one and take the truck for a lil drive.
99FlowedTaco said:
nice work man glad to see you finally doing your swap.
thanks for the diff mounts
Discussion Starter · #7 ·
i also wonder from those who have done the swap. I had one connetion that i couldent hook up to the A340F i think it is a speed sensor. After some reading it looked like the A340F had more then one speed sensor. is this one just not needed. No check engine light went on when i turned the truck on. though i havent driven it yet
if anyone could shed some light that be awsome. thats the only problem so far.
The speed sensor is located on the tail housing at the back of the t-case. Looking over your pics, it looks like you're t-case did not come with one. Instead, it's got a plug where the sensor should go.
I was not able to swap my PreRunner speedsensor as it would not fit correctly. You can give it a shot but be prepared to search junkyards if you can't find one. I was lucky enough to find one at the junkyard that I picked up my 4x4 trans from. They had another trans and t-case that had the speed sensor on it. Keep in mind that the speed sensor wiring will need to be extended but it's straight forward.
Discussion Starter · #9 ·
yea i thought something went there... i pulled it out... and bulled the sensor from my prerunner tranny but it was too too small... I am goign to the wrecking yard tomorrow.. im going ti bring that plug and se if i can swap it
Discussion Starter · #13 ·
yea i need to edit a few things.. like the sensor.. that im missing ( i have a plug in its place, so i need to make a noe to check for that) all in all this swap wasnt to exspensive.. $500 for tranny and front diff $50 for shifter boot and tranny mount $60 for 4WD hub/spindles, vacume tank and solinoids $110 for new CVs and Prob $60 for the drive shaft, and the sensor i was missing... total $780
that sensor is around 350 from toyota iirc.
my t-case didnt come with one either. i found one off a member here.
Discussion Starter · #16 ·
padesertboy said:
yeah, welcome to wheelin.
I`ve seen a bunch of these recently, why not just
BUY a 4x4? Are ya swapping in an early toy t-case
w/ 4.7`s?
Most be something I`m missing...
i didnt have the money to buy a 4x4 tacoma at the time at least not a V6 ext cab auto.. so i got my prerunner. never intended to do this swap untill i came across the parts for so cheep, then i just decided ehh why not
very good write up
wow, very impressed, quite an undertaking looks like you did a good job, i hope everything works out well.
Discussion Starter · #19 ·
got the Speed sensor today $75 from the local toyota wrecking yard. if anyone is planing on doing this, make sure you have the sensor.
you can drive without the sensor, but it will throw a check engine light and you will have no speedo or odo
1 - 20 of 40 Posts
