1 - 15 of 15 Posts
I've got a '00 Jeep TJ with a 4" lift and 33's that I really enjoy. Of course it's not very practical when it comes to hauling much more than a couple of people and very little extra gear. I understand that a properly set up a Taco should keep up with a TJ quite nicely in the trails we have here in Colorado, so I'm beginning to look around.
I know Toyota has a great reputation for reliability but honestly neither of my Jeeps has ever given me a moment of trouble.
I know I want the V6 over the 4 cyl.
Ambivalent on stick vs auto - unless the auto is short-lived like some others are known to be.
I'm living w/ my gas mileage now just fine - so if it gets better w/ a Taco then that's just gravy as far as I'm concerned, but don't want to go backwards.
I do not want the 4dr. - personally just don't care for the look nor the shortened bed. But not the standard cab either - the access cab is just fine. Best would be if there's half-door like on my buddy's Tundra, but that's not a deal-killer.
I prefer the body style pre-05, but not sure what changed year-to-year in that time. Currently looking at '00 - '04's but if the late 90's are still the same may go that route and put the cost difference into the lift/tires.
If the standard bed is 6', I may opt for the long bed - but they seem to be hard to find. I need to be able to haul up to a single motorcycle without the rear tire being supported by the tailgate.
It looks like it's worthwhile to hold out for a TRD if only for the locker.
Even with it's short wheelbase, my TJ has been able to get around very well on snowy roads regardless of how much we've had (and need some now!). My experience with pickups is that they're very light in the rear unless you add sandbags so they tend to be squirrely in snow - so how does the Taco do on the road in the snow?
I know it's no land yacht, but how comfortable is the Taco on road trips? -- regional, not cross-country type. I might as well not answer the phone in my TJ and road trip can wear you out.
Does the 3.4L have enough guts to load the bed w/ gear and still pull a motorcycle trailer with three bikes w/o lugging it in the mountains?
Is the Tundra so much bigger that it won't follow a Taco offroad?
Thanks Guys! Please feel free to correct any misconceptions, opine on these and other considerations I may have missed.
Timber
Moderator
Welcome to CoTTORA. Did the jeep have lockers? If not you will be amazed at where the locker in the trd taco will take you.
As far as power the 3.4 is about the same as the jeep 4.0, it just likes to be reved alot more.
Both the auto and manual transmission in the older gen tacomas have great reputations.
Expect a extracab tacoma with stock tires and gearing, with the v6 to get anywhere from 17-20 mpg.
Tacomas don't come with a suicide door like on the tundras, the only option for an additional door is the 4-door.
The tacoma name started in 95.5 year, and the grills changed in 95.5, 98, 2000. Watch out for some early 3.4L as they had head gasket problems, many of which were fixed through a TSB Toyota put out (years affected 95.5-97, 3.4L tacomas)
The only size beds you can get depend on the body style in the older tacomas. The extracabs and standard cabs only come with a 6' bed. The 4-door tacomas (pre-2005) only come with a 5.5' bed. You will most likely won't be able to fit a motorcycle in the bed with the tailgate up, unless you have a really short bike.
Me personally says that if you are planning on taking it offroad, then yes wait for a TRD with the locker. If you are going to be doing some hardcore crawling, probably pickup a non-locked tacoma, as the diff is stronger (8.4" vs 8" rear).
Both of the tacomas I have owned have done great in the snow, I have had in both trucks an over the rails toolbox loaded with about 100# of stuff, which probably helped.
Don't plan on having anyone in the back seat for an extended period of time in and extracab. The double cabs are pretty comfy in the back (for a mid-size pickup), I must say.
Yes. And I say that if one knows how to utilize it's powerband. On hills, if you keep a heavy load at 3400-3600 RPMS it will pull nicely. Just don't lug the engine with low RPM's when pulling, not only is it bad for the engine, it won't produce the power needed.
Depends on the trail and the tundra you are talking about. The older gen tundras, are about the same size as the new tacomas. The new tundras, good luck getting one past a trailhead.
Timber
Thanks. Nope, it has open diffs front/rear.
So it doesn't have the same low-end torque?
What's your budget?
05+ Access cab have the half-door
Strength difference in the "8.4" and the "8" diffs is quite negligible. The elocker is WAY worth the slight strength decrease as your only other option for a selectable is ARB. More info on Toyota diffs/axles:
http://home.4x4wire.com/erik/diffs/
One thing you will notice coming from the Jeep world is that there is not near the aftermarket support. Selection is a bit limited (compared to Jeep - very good support compared to just about everything else) and prices a bit higher.
If I were a real hard core wheeler I'd build a crawler and buy a diesel truck to haul it to the trails.
Our two dogs (lab and jack russel terrier) would be the only occupants in the back seat for anything other than a rare instance.
Discussion Starter #7 (Edited)
What's your budget?
Before mods - max of $15k. Like I said, if the last change was 2000 (before the '05 redesign) I could go with an earlier (like '00, '01) and put the "extra" into mods and come in under budget (for the first time).
Probably so, but then my Jeep isn't built very extensively. With the 4" lift, 33's and open diffs it's taken me everywhere I've wanted to go. Maybe I've got low expectations, but I find 4's and 5's enough of a challenge w/o trying to tackle Holy Cross or Independence.
Might be worth your time, with two dogs, to look at the cab space of a 1st-generation Tundra or 2nd-generation Tacoma. The former is easier to modify for larger tires, and has the V8, the latter is more efficient and arguably has a stronger front drivetrain. They're both great trucks.
The 1st-generation Tacoma is pretty much the standard for a capable stock pickup, you can't go wrong with it, if the space in the cab and bed suits you.
All these (gasoline) Toyota engines like to rev...not like the badass inline 6 in some of the Jeeps...but Tacomas and Tundras really, really get up and move and they're very stable at high speed. You can get a huffer for the V6 in the older Tacomas, and on the older Tundras with some engine mods.
The trucks are great for camping, road trips, long wheeling trips and multi-activity trips where you need to throw dirty bikes, hiking gear, etc. somewhere...the front suspension, wheelbase and track width make for a completely different feel than a Jeep, and you'll find you don't want to give up the TJ (I certainly wouldn't ;)), since they'll excel in different areas.
Bring your TJ and come wheeling a few times, jump behind someone else's wheel and see what you think.
-Sean
Discussion Starter #10
I thought it was exactly the other way around - that the Taco was much easier to lift. For the kind of wheeling I do, 33's suit me fine.
Move completed: I bought an '03 Tundra AC this weekend.
Now for the building phase.....:cool:
Can't go wrong with Toytec products for the lift. Doug is a member and the owner. www.toyteclifts.com Has most of it covered, spacers to coilovers.
Welcome! Yes talk to devinsixtyseven for sure as he is our resident tundra expert, and can point you to some good links and site that are specific to tundra!
But be sure to wheel with us for sure. We have a great run coming up (Tripple ByPass) that would be a perfect first trip in your Tundra. It is on Aug 1-2 and is in the plan a trail run folder!
1 - 15 of 15 Posts
