the dealer recommended me getting my throttle body service after they did my 30k service. what exactly is involved in the throttle body service? how can i do this myself instead of getting reamed by the dealer? thanks...
To my understanding the intake plenum is the two piece aluminum thing after throttle body. I think you mean the black rubber tube before the TB.ShowStop said:Remove the intake plenum so you can see into the throttle body
I forgot where I read this, but putting a rag on the bottom of flap works well to both keep the flap open and collect the gunk you will be removing with the TB cleaner.ShowStop said:Take some throttle body cleaner and spray it all around in there
Using a brass brush, clean around the inside of the throttle body in all areas you can reach (Dont drop the brush!)
DCabTaco said:I forgot where I read this, but putting a rag on the bottom of flap works well to both keep the flap open and collect the gunk you will be removing with the TB cleaner.
ShowStop said:Ok, first off, what you posted isn't anywhere close to what the dealer will do. Second, there is no real need to remove the throttle body housing to perform this service.
Switch between brushing and spraying the throttle body to clean out everything you can reach
Once everything is clean, close it back up and start the engine
Run the engine for about 3-5 minutes to warm it up
Run Seafoam or similar cleaner (BG products has a nice alternative to the Seafoam) through the PCV vacuum line (don't dump the whole thing in at once, the liquid should really be released slowly to prevent possible hydrolock)
Your done
Thats what the dealer will do
Yeah, thats what I meant.DCabTaco said:To my understanding the intake plenum is the two piece aluminum thing after throttle body. I think you mean the black rubber tube before the TB.
Yeah, I forgot to mention that. Another good tip!DCabTaco said:I forgot where I read this, but putting a rag on the bottom of flap works well to both keep the flap open and collect the gunk you will be removing with the TB cleaner.
