I've searched high and low on four different sites already...
I have a thumping noise/vibration coming from my drivetrain and can't really isolate what is causing it. The sound is not metal to metal, but literally is a "thump, thump, thump, thump". It starts around 30 mph and gets progressively louder and faster as the speed increases and never goes away. The noise is worst when coasting at speed and moderates under heavy acceleration. It sounds like it's coming from the rear, but I can only hear the sound inside the cab and nothing while driving alongside a road barrier or whatever.
I have recently put Deaver 8 leafs in the back and Donahoes in the front, which only increased the "thumping". I have removed the rear drive shaft and drove around in 4, but the problem remained. Any ideas? What does it sound like when the transfer case is going out? I just don't want to start replacing stuff without a plan. The truck really sounds like it is going to break. Unfortunately, the driveline shops in the area just want to start replacing parts to isolate the problem and I know throwing cash at it is not going to fix it.
Should I remove the front shaft and try that too?
