My 2003 is at close to 90k and I am wondering if it is time to start changing out all the stuff that makes my engine not blow up on me? If so is there anyone who has done the work themselves or would this be a real mechanic type ordeal??
call your local parts supplier and ask for a timing belt kit...it will have pullies included with the belt. and it tends to be cheaper. also replace the H2o pump. you shouldn't need to replace the tensioner, they usually last alot longer.
Put toyota red coolant back in it, not green. and buy import parts, not the cheap checker/autozone crap.
Good luck, and pay attention when you take it a part. you'll know if you missed a tooth in the timing.
I recently replaced the left front wheel bearing on my 95 Tacoma. It drives smoothly now and is quiet.
However whenever I brake now, I can hear (and feel in the brake pedal) the ABS system activating as I slow to about 5 mph. Otherwise everything seems fine. The ABS light is not on.
When I...
I need a driver side head.
What are your thoughts on After market heads any good brands? Remanufactured heads? Purchasing OEM? Amazon, Ebay, Autozone, Rockauto? Should I do both heads while I am here? Or just adjust valves on the other side, lap them, or leave it alone (not broke don’t fix)...
I currently have the Toytec 3'' lift with Dakar rear springs. This has allowed me to get by with 33''s, but of course they rub a bit. I am going to do a SAS coming up over the next couple months and was looking for a bit of advise. I know there are tons of threads on the matter, but I don't...
5VZ-FE Load Hesitation, Stutter, Sputter *SOLVED*
I've been chasing this engine stutter for about 1 week now. When parked if I rev the engine with more than 1/2 throttle it will sputter till about ~2,000 RPM. It feels like a misfire with out the CEL. The best way to explain it is a popping...
hello
i bought a used 2004 double cab auto with what looks to be an inchworm taco box with a 4.7 kit and inchworm adapters connected to a stock push button transfercase. i drained the first case and it looked like looked like a half a quart of redline gear oil. the rear case had two quarts of...
