1 - 2 of 2 Posts
hey i have a question, im gonna be needing new tires soon so i was thinking about going up to a 33x10.50 from reading around it says the biggest tire people would put on with stock 4.10s is a 32. well i was looking at tire specs and it says that the 32-11.50 bfg mud weighs more then a 33-10.50? In this case wouldnt it have almost the same affects as running the 32, as it would running the 33?
the mass of the tire does have an impact on the truck, but the impact is very small. the issue with the diamater of the tire is that your truck was set up to move a 31" tire not a 33" tire, so no running a tire that is skinner that is taller is not the same as running a shorter fat tire. you have to change your gearing when you change the diamater of the tire.
1 - 2 of 2 Posts
