I have a 2004 double cab with a 1" Daystar body lift and a 2-1/2" Fabtech suspension lift. I wanted to know if I could get 33x12.50's on the Taco. I also have a set Rock Crawler 16"x8" wheels with 4-1/2 backspacing.
I measured the wheel wells and up front I think that I would have to trim the fender flare on the inside but other than that I think that they would fit.
Any thoughts?
the biggest problem is the backspace you have.you will be rubbing your upper arm and the frame. maybe a narrower tire like a 285/75/16 would work alittle better :2cents:
truck ~n~ tow
3.75 BS is yer best bet...
Otherwise you'll rub the frame to shiat and rub the UCA... especially aired down...
285's or a 11.50 will need 4.0 BS
I know that the 12.50 will work with 4.0 BS... But it is too close for my comfort... And you rub the frame plenty at full lock and just barely clear the UCA aired down
If yer a street queen then non of this shiat matters and I don't give a fuck... ;)
