1 - 3 of 3 Posts
Well shit… looks like I have a broken bolt
I am running a TM 6inch...
After going through the truck, I found a broken bolt on the knuckle retainer plate from the 2nd strut...
http://pg.photos.yahoo.com/ph/[email protected]/album?.dir=/b645&.src=ph
Looks I am making a run to Home Depot for a 3/8” bolt by 1”
Does anyone know if I can take out the retainer plate without having to put the truck on jacks??? I dont think I need to jack the truck up... but want to make sure... I need to take off all the bolts in-order to possibly to get the broken bolt out….
I’d appreciate any info.. thanks !
You should be able to do it without jacking up the truck. I say if you jack it up and remove the botls the strut i more likely to slip off while it is getting extended.
L8R
Roger
Thanks... Hopefully it all works out...
1 - 3 of 3 Posts
