Has anyone thought of using the 3rd brake light as an amber? the wires are up on the roof and i cant imagine it being that hard to find a clear or amber lense and putting LED bulbs in there, what do you think?
Also randy and the few otheres with in cab cages, how did you route your tubing around the front of the dash? and where did you go threw the floor at, can you snap some pics of it? my main concern is im a manual and i need room for clutch, also i dont want to cut into the body mounts. did you keep that stock center bar that everything is mounted on or did you replace it, i know not use incorperate that actual tube into the cage (its like .025 wall toyota thin), but im just wondering if it would be wise to replace it or just use some 1" to tie it to the cage (just to secure it more)
