Save your money. I've heard from a couple of people that it improved their throttle response. It's not worth it. You'll get more from doing the deck plate mod.schcott said:im sure people have heard of the tornado. supposed to increase miles per gallon. i was just wondering if anyone has one, or knows anything about them. thx for your time
Agreed, stick to what worksMDTRD said:Save your money. I've heard from a couple of people that it improved their throttle response. It's not worth it. You'll get more from doing the deck plate mod.
it's a scam.. it just blocks the flow of air.schcott said:im sure people have heard of the tornado. supposed to increase miles per gallon. i was just wondering if anyone has one, or knows anything about them. thx for your time
Junk.schcott said:im sure people have heard of the tornado. supposed to increase miles per gallon. i was just wondering if anyone has one, or knows anything about them. thx for your time
My friend tried one of these about 3 years ago on his Jeep Cherokee and didn't notice a difference. My opinion is don't waste your money.schcott said:im sure people have heard of the tornado. supposed to increase miles per gallon. i was just wondering if anyone has one, or knows anything about them. thx for your time
go to a boat store that sells marine supplies.ask for a 3inch deckplate.3rdidvet said:Where can you get the deckplate kit, and how much does it run? I have a 2.7l and will try anything for a couple more horsies here and there!
Would you happen to have a brand name or know where I can get a sensor safe silicone. The rubber seal inside my airbox is coming off, I need to glue it back on.KRYPTO(dale) said:go to a boat store that sells marine supplies.ask for a 3inch deckplate.
basically,all it is,is a hole with a screw on lid.
then you cut a hole in the airbox(to fit the deckplate) seal it with sensor safe silicone stuff and voila!:clap:
permatex-any parts store will have it.pretty easy to find.alex9021 said:Would you happen to have a brand name or know where I can get a sensor safe silicone. The rubber seal inside my airbox is coming off, I need to glue it back on.
http://www.google.com/search?q=deck+plate+mod3rdidvet said:Where can you get the deckplate kit, and how much does it run? I have a 2.7l and will try anything for a couple more horsies here and there!
I have the 2.7, and the deckplate mod didn't look to easy to do on my truck. Most people do it on the 3.4 because the front of the airbox is flat. Mine has ridges on it, so the deckplate would require some time to put in.3rdidvet said:Where can you get the deckplate kit, and how much does it run? I have a 2.7l and will try anything for a couple more horsies here and there!
Thanks, I'm glad I waited a little before gluing it back on. I was going to use regular rubber cement.KRYPTO(dale) said:permatex-any parts store will have it.pretty easy to find.![]()
