1 - 1 of 1 Posts
http://www.davezoffroadperformance.com/store/drivetrain/differential/parts/toyota-high-pinion-builder-kit.html
High pinion builder kit,
The kit will include everything that you will need to upgrade to a High Pinion differential if you already have a v6 locker.
Yukon High pinion differential housing
Yukon High pinion oil slinger
Ring & pinion setup kit
Solid pinion spacer
USA Ring & Pinion gear set
Triple drilled flange
All for only $540
We even have you covered if you have a 4 cyl locker or carrier.
Sleeves for the journal on the 4 cyl carrier or locker so the V6 bearings will press on.
1 - 1 of 1 Posts
