1 - 3 of 3 Posts
Has anyone experienced what sounds like transmission whine/rattle only at 1500 RPM, in any gear? If so what did you do to fix it?
NorCal Chapter Pres
Does it occur in neutral? Sounds like a bearing on the input shaft...
sounds like a throwout bearing
Throwout bearing will only make noise when any pressure is put on the clutch. It doesn't spin when no pressure is on the clutch...
1 - 3 of 3 Posts
