I recently made some modifications to a 5VZ-FE in a 2004 Tacoma, Double Cab, 4X4, in the way of a TRD S/C, 7th Inj., Headers and cat back system. These have all been great improvements, however I am suffering a significant problem due directly to these modifications and I am wondering if I am alone.
I have had the chance to do some very lengthy reading from a wide range of resources, including URD, talking directly with TRD and reading up on tuning. From what I have been able to gather, when my engine is put under a boost induced High Gear/Low RPM state, I witness a very audible pinging that brings detonation to mind.
I have only been able to come up with a couple of factors that might be in play. I have had consistant feedback from all around me that the 7th Injector does'nt kick in until 50% throttle. My pinging only happens when I am in high gear and low RPM (under 3000) and I increase throttle. I've heard that the timing on the 7th Inj. ECU might be way off and if that is the case, TRD will only offer to refund the kit, not re-map or re-tune the Inj. I have talked to URD about their Injector Controller and it sounds like it may fix things.
I have also thought of removing my 7th Inj. and putting Bosch 318cc in place of the stocks and changing the fuel pump to a 190 LPH and learning the hard road of tuning and getting an FTC and trying that road.
I turn it over to a crowd that knows tacomas best becuase we all drive them everyday. I want nothing less than maximum horsepower and torque and I'm basically down to needing to know what will give me these results; keeping the 7th Inj. OR ditching it, upgrading my stock system and tuning that.
Thanks so much for any advice.
Chris
Chris
