1 - 11 of 11 Posts
themariachi said:
I did do a search. I am looking at picking this truck up for a buddy of mine, it has a fabtech 6" lift and has been heavily modified, most odf the stock compnents are not there. Thanks for all the input this far. I understand that the TRD package is an Option and might not reflect in the VIN, so in this case all I have to look for is if it is an open or locked diff correct?
· Premium Member
More specifically, you're looking for the Electric locker rear end..Look for a "rr diff lock" button left of the steering column, and just to verify look at the drain plug on the rear end housing..Looking at it from the rear it should point to the left, or drivers side if it's an "E-locker".
Discussion Starter · #7 ·
Cool... Thats what I was looking for! Thanks TacoCrazy!
· Premium Member
No problem....
· Premium Member
the C said:
what if it has a rr diff lock button, but the drain plug is on the right of the housing....
Then it doesn't have a stock E-locker rear end..Rear end swapped for an open with a Lockrite maybe??
You can call any dealership, anywhere, and supply the parts dept with your vin and they can tell you what colour the inside of the glove compartment is. So, by extension...
1 - 11 of 11 Posts
