I didn't answer this part.4TACXOMA4 said:Is it just called a banding tool, or is there a more specific name for it.
On the tripod or tulip joint there are the two c-clips. I am talking about the one that is farther towards the wheel and is a lot thicker. Thanks.WATRD said:Bigger C-clip? Can you be more specific?
or u can just use a large hose clamp4TACXOMA4 said:Ok, now my problem is those damn clamps. How do I pinch that peice of metal to tighten the clamps. I have tried pliers, but they don't want to pinch. Thanks.
Thanks. I think I will go pick those up tomorrow.dsopac said:http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00947386000
It's doable without lock ring pliers but it takes a bit of patience. I used large snap ring pliers, flat heads, needle nose and linesman pliers. Don't remember what worked, but did both cv's , ball joints, etc. then found the lock ring pliers...
