1 - 2 of 2 Posts
i replaced the + battery cable due to corrosion last week and now truck wont start. i turn the key and hear the solenoid click in the engine bay and in hear a click in the cab. i also hear a slow "turning" noise coming from the engine bay. i have power to the truck it just wont start. i have searched and found similar problems but none had quite the same symptoms. any help/advice is greatly appreciated. thank you all!!!
fixed problem, it was the starter relay
Did you clean the inside of the new terminal and the post on the battery, or secure the + wires to the terminal correctly? Maybe you do not have a full good connection and you can get power but not enough to start.
1 - 2 of 2 Posts
